取消
显示结果
搜索替代
您的意思是:
LabVIEW 2010 Application Builder not licensed w/ Professional?
已解决!
转到解答
I'm running LabVIEW 2010 x64 with a disconnected "Professional Dev" license file, but my Application Builder is not active and is showing expired trial?
Anyone else have this problem?  Or suggestions how to fix this?
I left a voicemail with our NI rep, but I'm waiting to hear back.
0 项奖励
1 条消息(共 9 条)
6,786 次查看
Added screenshot.  For some reason I couldn't edit my orig message...
0 项奖励
2 条消息(共 9 条)
6,780 次查看
解答
已被主题作者 Stranman 接受
0 项奖励
3 条消息(共 9 条)
6,749 次查看
I have installed LabVIEW 2010 and imported my license files into the License Manager which shows the Professional Development System and Application Builder as licensed, but when I run LabVIEW it says that Application Builder is NOT licensed. If I choose to activate it then LabVIEW says the activation was successful, but if I run LabVIEW again it still shows Application Builder as unlicensed.
I have tried rebooting and have re-installed LabVIEW 3 times but still no joy.
Can anyone help, please?
下载全部
0 项奖励
4 条消息(共 9 条)
6,320 次查看
Sounds like you need to delete the default trial PDS LabVIEW license file in the directory given in the Solution above depending on your OS.  I've found that I've had a conflict on LabVIEW 2010 and 2011 Professional after installing my disconnected license files.
I don't remember the specific license file you need to remove, although it should have the form of "LabVIEW_PDS_PKG_10"
so I would suggest you MOVE all of the files in the directory it specifies for your OS into a new folder so that you do not completely delete them.  This will hide them from license manager.
Then you can activate with the disconnected license and it should activate application builder properly.
0 项奖励
5 条消息(共 9 条)
6,307 次查看
Thanks, I have moved all the files from the Licenses folder and have re-installed my license files through License Manager. All looks OK like it did before, but I clicked "Do not show again" to hide the License Status when starting LabVIEW. Any idea how I get that status back?
When I run LabVIEW it creates a LabVIEW_PDS_PKG_100000_TmpEthernet.lc file in my Licenses folder that stays there. Is that normal?
Cheers.
0 项奖励
6 条消息(共 9 条)
6,304 次查看
No, but as long as everything in your License Manager shows green, you're good to go.
0 项奖励
7 条消息(共 9 条)
6,302 次查看
I have spent the last 2 weeks playing with this issue. I have re-installed LabVIEW several times, tried cleaning out the registry, loading it on a fresh install of Windows XP and a fresh install of Windows 7. Still no joy!
The Application Builder shows green in License Manager, but still says "unlicensed" in LabVIEW itself, and there is no way to create any stand-alone apps.
Help!!
0 项奖励
8 条消息(共 9 条)
6,250 次查看
If you are certain you are supposed to have Application Builder, why haven't you called NI Customer Service yet?
I called with my problem, I received 2 return phone calls, and it was fixed in less than 24 hours.
0 项奖励
9 条消息(共 9 条)
6,244 次查看
