LabVIEW 2009 x64 and application builder
Hi
My organisation has just got a site licence for LabVIEW so I have just installed 2009 x64.
My question is this:
If I build applications written using LabVIEW 2009 x64, will they only run on 64 bit computers? I would test this but both my computers are 64 bit machines. I have had a brief look through the build specs but there doesn't seem to be anything about 32/64 bit compatibility.
thanks.
(3,130 Views)
Accepted by topic author eichlerjw
Does this help?
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
Q. Can I run an executable built with LabVIEW 64-bit on a 32-bit PC?
A. You cannot run the LabVIEW 64-bit Development System, Run-Time Engine, or executables on a 32-bit PC.
Q. Can I run an executable built with LabVIEW 32-bit on a 64-bit PC?
A. Windows can run 32-bit executables on a 64-bit PC. Therefore, the LabVIEW 32-bit Development System, Run-Time Engine, and executables can be run on Windows 64-bit.
Q. Can I have both LabVIEW 32-bit and LabVIEW 64-bit installed on the same 64-bit machine?
A. Yes.
Q. Can I build a 32-bit version of an executable from the LabVIEW 64-bit application builder?
A. There currently is not an option to create a 32-bit version of an executable from the LabVIEW 64-bit application builder.
(3,124 Views)
Perfect! Many thanks.
(3,100 Views)
