LabVIEW 2009 SP1 Run-Time Engine (Minimum) (32-bit) for Windows - Supported Features
Can some one please point out what features are supported by the LV RTE (Minimum ) [LabVIEW 2009 SP1 Run-Time Engine (Minimum) (32-bit) for Windows]
1) Is there a limit on the size of the exe which can be run on it?
2) Will this support additional modules like DAQ etc.,? Or do we have to chose the regular installer ( 170 Mb ) for that purpose?
3) If a list of what it does or does not support is available, it would be extremely helpful.
Thanks In advance. 🙂
Vijay
(3,514 Views)
You can follow this link and this link... Smiley Wink
(3,506 Views)
Anand,
I did go through both the links that you had sent earlier before posting on the forum. For eaxample refer the following link where it says,
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1599
It does not contain the full run-time engine, but will allow some executables to run.
1) What do they mean by 'some' executables. Is there a list of yay's and no's available?
2) Can someone from NI reply to this and shed more knowledge?
Vijay
(3,502 Views)
