LabSSH for PuTTY connection
 I want to use LabSSH library (from Labvolution), but got error. (See attached). Can someone help me?  I also tried with System Execution, got no output. Thank you in advance.
(1,757 Views)
There is no image attached.
If you are using LabVIEW 2021 or later, SSH is natively supported. LabVIEW Tools for SSH and SFTP
https://tmesystems.net/
(1,753 Views)
Don't know why my image file wasn't attached. I put it again.
I did try with LabSSH library and plink on System Execute.  I am using LabVIEW 2023 Q3.
(1,704 Views)
I do not have much experience with labSSH.
Since you use LabVIEW 2023 Q3, why don't you try the built-in API? It is under Data Communications >> Protocols >> SSH palette.
(1,692 Views)
This might be a good suggestion. I am trying to use the "execution" function.  Do you know how do I set the "additional Options?
I use "Blank" for options and assign the user@host and command as below. I didn't get error, but the command "exit" doesn't function when I have the jumpbox open. Is my user@host wrong? Appreciate your help.
(1,681 Views)
I am not familiar with the jumpbox but it is giving me the same behavior.
(1,669 Views)
