LabSQL and timestamp problems
Hi All. Have you ever used LabSQL before?
I have encountered the problem with timestamp.
When i run mysql commands, like select * from table,  the table that has timestamp. so when I query it in mysqlenvironmental. it outputs like 20080117172155.
However,  when I query using LabSQL and MySQL driver, instead it outputs like 1/17/2008 5:21:55 PM. I would like to use it in the same format for querying later.
it will be difficult to convert it as all PC carry the different settings in the format.
Pls advise
Clement
(2,540 Views)
(2,537 Views)
