04-23-2013 12:15 PM
Just recently started working with Labview and I am using it as the control for a project. I have listed the purpose and components below.
If anyone has any tips, suggestions or set up for Labview that will control all or any of the below it would be appreciated.
Noel
Function
Automatic bottle filler. Liquid to be inserted and 6 bottles to be in system.
Components
Process to be controlled via Labview
04-23-2013
12:34 PM
- last edited on
10-13-2025
10:35 AM
by
Content Cleaner
a state machine would be perfect for your application
04-23-2013 01:57 PM
12-02-2016 09:31 AM
Is this using SCADA(DSC module)? If not then can you please upload it?
12-02-2016 10:06 AM
Did you actually look at the code??? Apok's example is just a simple state machine framework to explain to the original poster how to start his project. It contains no code to actually move or sense the bottles position or weight. There's nothing in it that interfaces to any hardware, SCADA or otherwise.
If you need a complete and operational system design based on the NI DSC module I suggest you post your request in the jobs forum or contact an NI representative for advice. This forum is for helping people learn how to use LabVIEW. ![]()
