LVOOP objects via Network Shared Variables - State-of-the art
I'd like to share LVOOP objects between a PC and the cRIO RT via network shared variables (SV).
As far as I know, LVOOP objects cannot be directly sent over SV.
Is there a recommended workaround?
Some of the options I'm aware of:
1) Serialize into string/variant; with following issues:
2) Serialize into fixed-size cluster
  • Any known disadvantage?
3) Other ways??
Many thanks,
Peter
Some older sources:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Shared-Variables-should-support-LVOOP-as-a-data-type/i...
(2,685 Views)
Hello!
I recommend you use the flatten2string function and send the objects via network shared variables, or, preferably, network streams.
I think there are no generic disadvantages to name here, it all comes down to how you choose to design your application.
Like for the RT FIFO: No variable sized data types can be used here, but do you really need to send entire objects through?
Hope this helps!
Kind regards,
Rome
NI Germany
(2,615 Views)
Hi Rome,
thanks for your help!
What I still don't see is what a buffer adds to a network shared variable with RT FIFO? Isn't a FIFO already a buffer?
You may want to have a look at this thread: http://forums.ni.com/t5/LabVIEW/Shared-network-variables-RT-FIFO-versus-buffering/m-p/2648035/highli...
Peter
(2,606 Views)
