LVOOP Class methods execution
I have a question regarding the execution of class methods.
Lets say i have Class "A" with a method called "Do something" which is set default to "Non reentrant execution"
and I instantiate 10 objects, in different threads which run asynchronously.
If i call the method "Do something", is this running in parallel? Or do I have to use the "reentrant execution" option of the method in order to get parallel execution.
Thanks!
(1,703 Views)
Accepted by topic author GMarian
Method has to be reentrant if you want to execute multiple instances of it simultaneously!
Lucian
CLA
(1,671 Views)
Thanks!
(1,653 Views)
