LVDT
Hello
My name is Joaquin.
I have LVDT from HBM typ wa/300mm connected to PCI 6036E.
I would like to create a VI to measure Position and time. It is possible to measure the speed with this instument? Where can I find a good example?
I dont need anything complicated. The only example i found in my Labview is not what Im looking for.
Thanks for your help
Joaquin
(3,681 Views)
Hello Joaquin,
Please post DAQ questions here.  It helps our community find information faster and easier.
There is actually a great Dev Zone article here, that explains how to measure a LVDT using NI-Products.  There is a section in this document for connecting the LVDT to a SCXI-1540.  The SCXI-1540 has the signal conditioning built-in for reading data from a LVDT.
You could just use a shipping example that would read differential data continuously.  You can use a DAQ Assistant within a while loop for a simple and easy solution.  Once you have acquired the voltages, the data would need to be converted into linear distance.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,641 Views)
Hi Rob
Thanks for the information.
I made this little program. I want to modify it to measure speed or even acceleration. It is possible?
Thanks again
(3,618 Views)
Hello Joaquin,
I would suggest using a DAQ Assistant. (Functions Palette >> Measurements I/O >> DAQmx – Data Acquisition >> DAQ Assistant) It is very similar to creating a task in Measurement & Automation Explorer.  Once you are able to get your DAQ Assistant setup correctly, you can then convert that Express VI into DAQmx code. (Right-click on the DAQ Assistant and select Generate NI-DAQmx Code)
Respectfully,
Rob F
Test Engineer
(3,595 Views)
