I'm student researcher, I have recently been assigned by my supervisor to determine a suitable LVDT and accompanying equipment for some research experiments that will be undertaken.
I have done my own personal research and still can’t determine 100% what I need. The system that the LVDT will be used on has a NI BNC 2090 which is connected to a DAQ.
Is the BNC 2090 compatible with 0-10VDC or + - 10VDC outputs
In what cases will it be necessary to use an LVDT amplifier? Is it even necessary to have an amplifier? Are there any cheaper alternatives?
Also, when they say signal conditioner does that refer to the amplifier?
Am correct in saying that DC LVDT's dont require amplifiers and AC LVDT's require amplifiers?
Is it possible to provide a schematic diagram how it all will be connected to eachother?
So far i know that i need a 24vdc power source (depending on what i get) other than the LVDT itself.
Sorry for asking so many questions, I am very new to all this.
Rabih
Hi Rabih,
The BNC-2090 is fully compatible with analog output from 68-pin M Series, S Series, E Series or B Series DAQ devices. The signal path is very simple, you can see it on page 24 of the manual.
National Instruments has a portal for LVDT/RVDT/Resolver measurements that can be found here. There are a number of great links to National Instruments articles about understanding LVDT technology in that link.
Signal Conditioning/Amplification will usually be needed. Signal conditioning to take the AC output and turn it into a DC voltage representative of the LVDT location. Amplification to use the full resolution of the Data Aquisition device.
Have a great morning,
MatthewW
Message Edited by Matthew W on 01-21-2008 02:45 PM
