LV8.2 driver to Agilent N5182A
Can anyone tell me if the driver already exist to this Vector Signal Generator?
I assume it would be not much of a difference fromt he typical formation as used in hpesg and agesg driver packs...
Thanks in advance,
Boris.
(3,096 Views)
Did you look on Agilent's web site? A simple search would have turned up that IVI drivers exist. These can be used in LabVIEW.
(3,082 Views)
Hi Boris,
Here is a link to a tutorial that describes how to use the IVI-COM drivers in LabVIEW. The usual IVI instrument drivers are IVI-C instead and would be a bit easier to use. However, the IVI-COM drivers should work. I hope this helps!
Missy S.
Project Engineer
RoviSys
(3,064 Views)
