LV8.1 - Make a VI with a multi type input
I would like to konw if it is possible to make a VI where an input can have different type, and also, the output type get the same type of the input. In order to create a generic VI.
(2,357 Views)
See this document which explains you to build polymorphic VIs. Depending on your LabVIEW version (base, full, pro...), this functionnality will not be available.
(2,356 Views)
