LV7.1 DSC tag engine VS LV8.6 DSC shared variables
I'm currently running LV7.1 with DSC and RT. To handle communications and logging RT variables I'm using the init / read / write publish.vi's on the RT side and datasockets on the HMI side (Windows XP). This has worked out great - new tags can be programmatically created in real time with the publsih vi's and then I go to the the .scf file and use the tag configuration wizard to add them to my scf file and handle data logging. This worked very well - the wizard would organize all of the memory tags into folders by block name used by the init publish vi. I could also select entire groups of tags and add hundreds at a time to the .scf file. Hardware Tag also worked in a similar fashion, organizing tags by controller and module folders. Now - looking at LV8.6.I found I can still use the init / read / publish vi's on the RT side - great. However there is not tag configuration editor as in LV7.1 to let me add large numbers of tags through a wizard. The closest thing I've found is to create a library to represent each block name from the RT init publish.vi then use "create bound variables" option under the library to bind the new shared variables to the RT memory tags. I can browse to the tags on the controller by network items, but when I add them it doesn't bring the block name of the tag as it did in 7.1, only the item name. I use a lot of PID loops that share the same tag names (i.e.: P,I,D, mode, output), so not including the block name represents an organizational problem. The problem with this is, it's very labor intensive compared to the wizard in LV7.1 DSC, especially talking about creating systems with thousands of RT memory tags. Also, there is a similar problem with hardware channels (I'm using compact FieldPoint). To log channels via DSC do I have to create a shared variable for each channel to access the DSC logging capabilities? Again how do I add all of the hardware channels in some organized fashion? I hope I'm missing some tool that is an analog to the tag configuration wizard to bring in these channels and organize them. Any help or suggestions would be appreciated. Thanks,Brad
Message 1 of 1
(2,585 Views)
