11-14-2005 04:21 PM
11-14-2005 06:20 PM
11-15-2005
10:44 AM
- last edited on
06-27-2025
05:19 AM
by
Content Cleaner
11-15-2005 01:00 PM
11-15-2005 01:08 PM
@DerekSRD wrote:
My last interaction with LabVIEW and hardware was using "Traditional" NI-DAQ. Hopefully that will give you some background on my ignorance! 🙂
Here's the situation, one of our test fixtures that has not been used in a very long time, decided to have issues when we tried to run it. It contains some legacy cards:
- AT-AO-10
- GPIB0
- PCI-6031E
- PCI-6503
No this does not mean that you cannot use LV8 this just means that you cannot use Daqmx with the AT card you will have to use the traditional daq. Do not worry because you are already using traditional and just don't know it yet. ie AI Read, AI write and so on. Heres what I would do since all versions of LV can coexist together. I would make a copy of the vi and give it a unique name that way when you open it in LV 8 and in case it does not work you will have a back up copy that has only been opened in LV 6.1. Install LV 8 and daqmx 8. You will like daqmx it is much easier to use than traditional.
11-15-2005 01:19 PM
11-15-2005 04:02 PM
11-15-2005 04:16 PM
11-15-2005 05:21 PM
11-16-2005 07:20 AM
