LV2017 Application builder issue
Hello
I have updated a test application for a device we are producing from LV2013  to LV2017. Now I have trouble, to generate the EXE-file.
The test application contains a packed library, that does the communication over Ethernet with our device with help of a UDP connection.  All is working fine in the LV2017 development environment, I could operate all functions of our device with the help of the test VI. Then I generated an exe-file with help of the application builder, and the application does not work. It shows the corrupted arrow, like a VI that does not work. I got also the notice, that a VI is not working, and I need the LV  development system to eliminate the error.
Inside the development environment all VI's show no errors,  I tried to play with the settings inside the application builder - always the same result, a non operating exe-file.
I also tried it out with LV2018 - same result. The exe-file does not work. I did also a mass compile of all the VI's before the build with no errors.
Does somebody have any idea, where I can start to look what is faulty here? Curently I can operate the
Operating system is Windows 7.
Message 1 of 8
(3,156 Views)
maybe a vi is pointing or call an object outside your project directory.
to eliminate this make a save project as and rename it to be sure
https://images.youracclaim.com/size/110x110/images/7c5d31f5-2069-4618-ba59-b710c2b6bbe4/CLD.png
Message 2 of 8
(3,139 Views)
Hi Simo22,
I tried this out, by putting a copy of the project folder on my laptop, that has no access to the original folder ant there the same problem. Thanks for your hint.
Message 3 of 8
(3,129 Views)
Typically, when an program works in the DEV environment but doesn't work as an EXE, it's often a missing dependency.  Did you try to Always Include the library file?
aputman
Message 4 of 8
(3,114 Views)
Hallo,
if you mean the settings for the source files, then: yes, I always included packed library in the build.
I have tried to build it local on my PC as well, as build it on a network place, always the same result exe-file does not work.
Today I tried to exclude parts of the structure, to see if it could be related to the code, and I set up a new build for the exe file - no result, all not working exe-files.
has anybody an Idea, where to search also for possible reasons that the program does not run after the build? I'm a bit helpless now, tried so many thinks ...
Kind regards
Guido
Message 5 of 8
(3,077 Views)
My thoughts are going to the PPL.  If things are not exactly where it expects, bad things can happen.  Does the PPL depend on any other PPL?
Message 6 of 8
(3,069 Views)
Post a picture of the error.  Does it popup with a dialog where it's looking for a certain file?  Or does it simply startup with a broken arrow?  Does your application use a .dll file and if so, is the application able to find it?
I've seen suggestions of:
  • clearing the object cache
  • disabling parts of your code and rebuilding
  • cleaning your build before rebuilding
  • disable the 8.x file structure in the build settings
  • look for diagram disable structures.  Delete the code instead.
aputman
Message 7 of 8
(3,066 Views)
Hello thanks for the reply,
  • At first, I made a screenshot of the broken app, see screen shots. The German text means "This VI is not executable. The full development version of LabVIEW is required to fix the errors",
  • I also included a screen shot that the packed lib should be included, but it makes no difference, if I build it with this option or not.  The packed lib will be always in the "Support Directory" specified for the build
  • .8.x file structure is disabled
  • Build was cleaned before the rebuild
  • object cache was also cleared before rebuild
  • I did also check the library with n new very small application, that has included the packed library, and I checked the main functionality of the packed lib. I could build an exe-file and start  this exe-file from the new application without any problems, so the library itself seems to work fine.
Guido
Message 8 of 8
(3,051 Views)
