LV2013. Problem with modified TS Operatir Interface (TSOI)
I have the version of the TSOI compiled and built in LV2010. It works as expected.
After sucessful compiling and building this application in LV2013, TSOI launches correctly, but when TS sequence calling the first step with LV module which suppouse to bring the front panel od the module on top, the two things happen:
  1. the FP is not brought oon the top (it is on the bottom)
  2. the module is not responsive
and I had to kill an execution.
Can anyone point me to the right direction why could it happen?
(2,411 Views)
Based on the service request you had open with us I believe this was due to the fact you were using TS 2010, which is not forwards compatible with VIs written in LabVIEW 2013. As previously mentioned I would recommend upgrading to TS 2013 for this functionality.
Kind regards,
Matt H
National Instruments UK
(2,325 Views)
