LV2012 crashes when opening LV2010 project containing OOP and dynamic FPGA references
I have a project that was written under LV2010 and has no problems that I am aware of. This project contains OOP and dynamic FPGA references. I am trying to upgrade this project to LV2012. When opening this project under LV2012 (or any subVI containing OOP) I get an error message, as shown in the attached screenshot. Has anyone else observed this problem? I haven't found any relevant postings on this forum yet.
My project is quite large, with many accessors.
Thank you for any assistance you can offer.
(2,245 Views)
Hi Chris,
I was able to find a discussion forum thread where someone had a similar error. Apparently it was due to trying to close the same reference more than once.
If that does not resolve the issue, I would try to open a different LabVIEW 2010 project in 2012 and see if you get the same error.
(2,205 Views)
Thank you for your response, but the Discussion Forums link that you provided refers to a problem that occurs when exiting a running executable. My problem is different. I am simply opening up a LV2010 project using LV2012. No running of my program is involved.
Anyway, after several days of work, I narrowed down the cause of the LabVIEW crash. My code contained a Disable structure, and within that Disable structure there was a subVI that had an unwired object terminal (set to dynamic dispatch). Deleting the subVI in the Disable structure eliminated the LabVIEW crashing. Weird behavior.
(2,168 Views)
