11-08-2010 08:14 AM
Hi all,
we have been using a LV code to make measurements with a spectrometer connected to our computer with a usb plug. It ran fine, the ActiveX being registered in the computere base. Lately, we upgraded LV for LV 8.6. It is now impossible to run our code. We have a "crash", meaning when we launch the program, it takes some long seconds with the computer working but with nothing operating. Then all LV windows are closed, with no error messages. Nothing. We tested the spectrometer with the manufacturer software, and everything works fine. The LV code is extremely simple and will be used after in a larger code. It basically consists in opening an activeX, calling one property, getting an array of values
Any idea of what's happening ?.
Mario
11-09-2010 08:15 AM
Hello Mario,
Thanks for posting on the National Instruments forum.
Can you give us more information about your system and the behavior you're seeing:
1- Which version of LabVIEW were you using formerly?
2- Are you using the same computer?
3- If you re-run the code with the former version of LabVIEW, does it work properly?
4- Did you create the simple example you're talking about from scratch or did you copy it from your project?
5- Can you really see the ActiveX Class you want to use into the ActiveX Class Browser (right click on the Automation Refnum)?
6- Do you reproduce the behavior with another class (from MS Excel form example)?
Have a nice day,
Flo
11-09-2010 09:02 AM
Hello Florent,
thanks for your reply. Here are the answers below
We developped it with LV 8.5, and LV 8.2. Tests and measurements were made months ago on two different computers (Dell Latitude). Worked fine.
No, the problem occured on a 3rd computer, a NEC one if I am correct, with LV 8.6.1
Yes, and no. Some issues occured. The PC crashed lately. It was formated and LV reinstalled from 8.5 to 8.6.
The code works but we have some glitches sometimes, as if it could not find yhe specvtrometer.
We created it from scratch.
Yes, once the ActiveX registered in the windows registry.
Not tested. Cannot say.
My colleague and I took a 4th PC a laptop (NEC) with LV 8.2 and wrote again the whole code (which is not too long so that was aceptable). It worked fine ! So now we have to figure out if the problem is the PC or our LV 8.6.1 version ...
Mario
