LV Startup error message - windows installer
Hello Everyone,
Whenever I launch startup LV, I get the attached error message. I had installed an application which was located in a network drive. The application was deleted from the network and from my pc. Its no longer used but whenever I launch LV, this message comes up (and at various other times). Is there any way I can get fix this it short of a full re-install?
thanks.
(2,468 Views)
Hi DavidT!
The image that you attached said that it is looking for "install.msi". If you had a shortcut to LabVIEW, it should have been pointing towards LabVIEW.exe.
Secondly, what do you mean by "I had installed an application which was located in a network drive. The application was deleted from the network and from my pc. Its no longer used...". By "application" do you mean an EXE file that you created using Application Builder in LabVIEW? If so, it shouldn't make a difference if you delete the application or not (for starting up LabVIEW purposes).
Maybe a better explanation of your situation might help too! However, if time is critical, I would probably just reinstall LabVIEW. It really doesn't take that long!
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
(2,460 Views)
