LV Example not working. DAQmx timing mode has no properties.
Just gone through our 3 year computer change out and our IS department has replaced the computer used on our Sound and Vibration room.  When I load the above example, the timing property node that should write the sample clock rate simple has no properties available.  If I right click on it I get a message "No properties"  I assume that something has changed during the swap as it used to work fine.  We are using LV8.5.1.  Any help appreciated.  Thanks
(2,540 Views)
Did you reinstall DAQmx? Look for it on your Device Drivers CD/DVD. If you don't have it, you can download it from NI.
(2,536 Views)
