LV- DLL as shared Mem
Hi LVers !
I have the problem to exchange data between two processes running on
WinNT. The first is for data aquisition and logging running every 10ms
and the second is for visualisation with an update rate of 250ms . The
daq is a LV application. What I want is to create a DLL (which is now
possible with LV6) as shared memory accessable by respective DLL
functions for writing and reading the dtata.
Any idea how to create such a DLL with LV ?
Hans Joerg
(3,499 Views)
Couldn't you just use Labview's DataSocket Technology? Create a
DataSocket data object and write to it with your DAQ process. Read the
datasocket with your display process. Or, if the processes are running
on the same computer, how about a plain old Global Variable? A DLL
seems the hard way to go. But if for some reason you must, there's a
white paper at NI's website detailing the process. Look for Application
Note 87, or try this search:
http://digital.ni.com/appnotes.nsf/websearch?Searchview&Query=an087
In article <3A2F4D78.EA5A8F1B@astrium-space.com>,
Hans =?iso-8859-1?Q?J=F6rg=20Beesterm=F6ller?=
Joerg.Beestermoeller@astrium-space.com> wrote:
> Hi LVers !
> Win
> Thanks
> Hans Joerg
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,499 Views)
look at:
C:\Program Files\National Instruments\LabVIEW
6\examples\general\synchexm.llb\Queue Example.vi
you can use queues to buffer anything from simple individual doubles to
arrays of clusters of ... by flattening/unflattening to/from string.
wrote in message
news:915cdl$cus$1@nnrp1.deja.com...
> Note
> > Hi LVers !
> > Thanks
> > Hans Joerg
> Before you buy.
(3,499 Views)
