LV 8.6 Remote Debugging - no block diagram
I have a built app on a remote machine that i am trying to debug , i have clicked the Enable Debugging check box under the Advanced options i teh Build Spec properties. When i build the App and connect to it using Operate -> Debug Application or Shared Library. I right click the front panel after it has loaded on my local machine and the only option is Quit Debug Session. What else do i have to do to be able to debug this this app ?
Dan
Message 1 of 18
(5,451 Views)
Hi Dan,
Are you able to connect to the application?  I take it you don't see the Show Block Diagram option like the last image in this KnowledgeBase?
Here are a couple other documents that take you through the process step by step as well as some troubleshooting:
How Can I Debug my LabVIEW Executable?
Why Can't I Find my Debuggable Application While Remote Debugging?
Message 2 of 18
(5,428 Views)
I have the same problem. I can´t switch to the block diagram from the front panel. But Im able to connect to the application. When I do click with the right mouse button it only appears "Quit debug session". I have already read the links about this problem. But the settings are ok.
My Request in Germany:
http://www.labviewforum.de/index.php?showtopic=17803&pid=109721&mode=threaded&start=#entry109721
What is the reason?
Message 3 of 18
(5,260 Views)
GT123,
   Is the code locked?
http://digital.ni.com/public.nsf/allkb/60EBDE971D01E73886256621007C00E3?OpenDocument
Ben J.
Message 4 of 18
(5,238 Views)
Hello Ben J.,
no the VI has no password protection or the block diagram wasn`t removed.
Greetings from Germany
Message 5 of 18
(5,224 Views)
Try hitting Ctrl+E to get to the block diagram. I need more information if its not that simple. Have you tried reopening it? Restarting the computer? Sounds like you are in debug mode in which case you can simply get out of it to get rid of the problem. Can you upload the VI?
Ben J.
Message 6 of 18
(5,202 Views)
Hello Ben J.
Ctrl+E does not work because I have no toolbar.
Reopening and restart isn`t the problem.
Here are 2 example Vi (LV2010).
Message 7 of 18
(5,191 Views)
GT123,
   Is this an executable or a development VI? What happens when you click on "quit debugging session"? A screenshot would also be helpful.
From Austin,
Ben J.
Message 8 of 18
(5,182 Views)
Hello Ben J.,
I have build an installer and then I have installed this application on an other PC. With the remote debugging I can log in the running application
an use them. When I  click on "quit debugging session" the application will stop an close. See the picture...
Message 9 of 18
(5,168 Views)
You say you have enabled debugging in the build spec.  But do you have debugging enabled in the the VI properties>  Execution page for that specific VI?  What is the execution priority set to?
Message 10 of 18
(5,163 Views)
