LV 2020 DSC installation problems
Greetings. I am updating from LV2017 to LV2020 on a new PC with Win 11. The problem is that, when installing DSC, the system gets stuck while installing the SQL Server 2012. Have tried different approaches, but it is always the same. Any clues? here is a screenshot:
 Thanks!
(1,207 Views)
Judging from this post and your other one, I'd say that you should take a deep breath, go back to Win10 + LV 2017 and stay there until you've thoroughly researched what you need to do to ensure that your upgrade path is a viable one.
Bill
CLD
(Mid-Level minion.)
(1,201 Views)
I already know what I need, it is just that the transition is not as smooth as expected, plus the software is not installing as smoothly as it should. I have been with LV since 1998 and my first system was based on cFP, from which I had to upgrade to cRio when it became obsolete.
(1,186 Views)
Unless it was mandated by your IT department, I would go back to what worked and take your time about this.
Bill
CLD
(Mid-Level minion.)
(1,179 Views)
