LV 2016 OPCUA Server built app and Installer fail on PC w/o LabVIEW
I have built a simple OPCUA Server in LV2016, which works fine in development environment.  The built exe works on the development PC (Win7).  The built Installer runs without error on the target PC (Win10) without any LabVIEW ever installed.  The exe starts up, but immediately errors about all the OPC VIs being missing due to resource not found.  The missing resource named is "ni_opcua_server.dll", which the Installer did place on the target PC.  What have I or the Installer done wrong?
bjlv
(2,947 Views)
Bjlv,
Have you installed the DSC Module Run-time System on the deployment machine?
This forum post describes the same issue: https://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/thread-id/802695/page/1
What is the DSC Run-Time System and When Should I Use It?
http://digital.ni.com/public.nsf/allkb/E56DB8726DB68F288625770E00594351
Kyle S.
http://www.ni.com/support
(2,875 Views)
