LV 2010 measurement I/O
Well this is embarrassing but I can't figure this out. I just installed LV 2010 distribution from an NI provided disk. All the updates were then applied automatically via NI over the web. In the Functions pallet under Measurement I/O the only option listed is NI Scan Engine, none of the DAQmx icons are there. It is almost like DAQmx is not installed BUT on the controls panel I can select the physical channel can put it on the FP. I also have LV 8.6 installed and every thing is normal there. I have an USB-6008 installed and it shows up and test OK from M&A.
Thanks for any help!
Alan
(2,960 Views)
You will need to install the DAQmx driver again. In your installation, was there a prompt for installing the Device drivers? If not, try to find that and install the DAQmx driver.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,951 Views)
There was no prompt to install drivers or not. Should I goto NI web site and look for drivers, if so what version will work with 8.1 and 2010?
Alan
(2,948 Views)
Forgot to mention the OS is XP SP3
(2,942 Views)
Accepted by topic author ajmartin
I am not sure if you have the NI Device Driver CD, since you can just use that. Otherwise go to http://www.ni.com/drivers/ and install the DAQmx driver.
Adnan Zafar
(2,938 Views)
Thanks, it is downloading now. Looks like another hour to go before it is done. I'll let you know how it works out!
Alan
(2,925 Views)
Thanks, I should have known that , but my 8.6 was working and even in LV10.0 it seemed DAQmx was working because I could create phys channels using DAQmx name controls  on the FP. I would think NI would have tested this better. After over an hr install of the NI  CD, I needed to DL a Gig plus driver file, that took over an hour, then another more than hrs wait for it to install. In all it took nearly 5 hrs to get this running.
Alan
(2,888 Views)
