LV 2010 SP1 and .net classes
When I drop a constructor node onto the block diagram, LV freezes for around a minute. It seems to work ok after that.
However, when I run the program, LV again freezes when it gets to the constructor in the code. Again, for around a minute.
I was hoping SP1 would fix this but nope. So, as a result, I'm forced to use an external exe written in C# do do what I need it to do.
Is there a workaround with this issue?
(2,612 Views)
Wayne,
Is it when you use any .net structures or only the one in your application?  A good way to check this is to go through the example finder to our .net examples and try running a few of those.
what version of .net are you using? have you ever successfully used .net items in the past on this machine?
Kyle Mozdzyn
Applications Engineering
Kyle M.
(2,585 Views)
