LV 2009 and LV 2010 parallel
it is necessary, that i use LV 2009 and LV 2010 on one system.
When I start LV 2010 it creates an entry in context menue in Windows Explorer "Open with" LabView 10.0 Development System.
When I start LV 2009 afterwards (not at the same time) LV 2009 delete this entry and i have only the options in "Open with"
"LabView 9.0.1 Development System".
Is it possible to change this? I want to habe both, independet from the LV Version that i used last. I tried to create an entry
manually by "Choose Programm" and select the LabView 2010 EXE, but Windows doesn't create this entry.I believe the reason
is, that both LabView versions have the same name, "Labview.exe".
(2,274 Views)
This should answer your question.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,262 Views)
