LV 2009 RTE uninstall
What is the proper way to uninstall the LV 2009 RTE?
It does not appear in the Programs list (i.e. add/remove), even under National Instruments.
Battler.
(3,545 Views)
Can anyone help?
(3,524 Views)
Hope Crelf can help
Mathan
(3,515 Views)
Thanks Mathan.  I had no idea it was going to be so tricky.
Perhaps NI has something more to say about it...
(3,491 Views)
Hi Battler
I have mention to you that msiexec.exe has a command line option. So why not use Google and search for ->msiexec command line
Google is your friend;)
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,483 Views)
Hello battler,
The reason why LabVIEW does not let you remove run-time engines because many NI applications have dependencies on he RTE (SignalExpress, LabVIEW Example Finder, drivers utilies, etc). If the RTE is removed, it could break all of the software. Were you able to uninstall the RTE following the steps in the other thread?
Andy Chang
(3,455 Views)
