LISTBOX with checkbox
Hi, does anyone knows how to make a listbox with text + a checkbox
(boolean), so that it is possible to check a specific item in the listbox?
Thijs Boeree
(3,125 Views)
Well, i've managed a workaround, but it only works in one direction (check the boxes >> selected in listbox) if you want it to work in the other (check the listbox >>boxes selected) you must use another local variable.
Hope this helps you
(3,125 Views)
Take a look in lv foder\examples\general\listbox.llb ... it seems to be what you are looking for.
hope this helps
(3,125 Views)
