LIN example for kvaser hardware
I am looking for example code for a LIN bus, simulating the master device.  I need to simulate the master and send a request to a slave device and I need to see the response for the slave device.  I am using Kvaser hardware.  I have had no problem simulating the slave device and recording messages from the master but can't seem to get it the other way around.  Thanks.
(3,598 Views)
Never mind, figured it out.
(3,581 Views)
  This is kunqiao, I faced the same problems as you did. Since you have solved that problem. Could you tell me where do you get that LIN example for kvaser? If it is okay that you send me your .vi file to me as reference. That will be great helpful.
kunqiao71@gmail.com
(3,475 Views)
TRWETWERT WERT
@Dray  已写:
(3,241 Views)
