LIN Communication with NI USB8506
Hello everyone this is my first topic after only read for many years today i have issue with "LIN Communication"
1. I want to test LIN communication with this product model i will call "ES2C"
2. I bought USB-8506 module and Setup X-Net driver
3. I have try to make DB (.ldf) for ES2C following the SPEC sheet (pdf "Global_B_PRNDL_CTS_2NOV2016_(A2SL_Silpa)[1].pdf")
4. I have try to command the ES2C (Turn on the light) buy following the SPEC. sheet
    4.1 4 bytes for command each bytes contains 8 bits
    4.2 2 bytes for Respondse each bytes contains 8 bits
5. I failed
Can you suggest and give me advice for my mistake i am very welcome for and comments, Thank you so much
(1,296 Views)
Hi Paladin60g
What the reason of your failure? I mean, from which point you couldn't carry on.
And also, I see that the post is quite old, and I hope you have already solved your issue.
Regards)
(1,137 Views)
