LIN Communication - Slave doesn't answer
I'm using a 9866 module in LV 2015. I have to communicate with a LIN Slave and I don't have the ldf file.
I have an other system that can play as master.
I create the ldf file with NI-XNET Database Editor and I read the communication between master and slave with the NI-XNET Bus Monitor.
I load the LIN Frame Input Output Same Port.vi and if I run it like the master (I turn off the other one) I'm able to send commands to the slave, but I'm not able to read the answer. If I turn on the other master and I run the vi without the master communication I'm able to read the slave answer.
Can someone help me?
Fabio
(5,019 Views)
What do you mean by "I turn off the other one" ?
If the frame you're expecting as a reply from the slave is in the schedule transmitted by the master you'll read it using an input session (queued or single-point) on that frame. You can look at the LDF file to make sure this is correct.
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(4,989 Views)
Hello Eric,
I have a customer master LIN that I switch off when I try to use the 9866 in MASTER mode.
Unfortunately I used the input session (queued) and I didn't receive any message. I tryed with Frame In Stream too with the same result.
I'd like to underline that if I run the customer master LIN I can read the messages from the master and from the slave on the NI-XNET bus monitor. I can read the messages on my VI (it is the example: LIN FRAME INPUT OUTPUT SAME PORT) too.
When I run the same VI like Master, I command the slave but I don't read nothing on NI-XNET bus monitor.
thank you very much for your help,
Fabio
(4,976 Views)
Maybe I wrong the slave NAD. Can I sniff the address of the slave?
Thank you,
Fabio
(4,967 Views)
Thank you,
Fabio
sorry, I read the ID from the NI-XNET Bus Monitor
(4,963 Views)
at the end I received the LDF. Now i didn't understand the schedule table. Can you help me to understand why I have:
1. command;
2. answer;
3. the same answer;
4. the same answer;
5. ….
like you can see on the attached picture?
(4,680 Views)
