LEDs programme
Note in the image below that some of the wires are "fuzzy." That indicates "constant folding." When the compiler finds code which never changes its output, that code is folded, or repalced by a constant in the machine code.  So the row index, the value of the replacement element, and one of the inputs to the not equal comparison never change.  Your simple math is so simple that your row index is always 0.
Lynn
Message 11 of 16
(1,658 Views)
bary77 wrote:
Now I have the following code.
As a first step don't complicate things with property nodes. Setting an indicator to disabled is completely useless, because they cannot be operated anyway at run time. All you might want to do is change the number of visible rows and columns.
Here's some simple code for you to chew on. Maybe it can give you some ideas.
Message 12 of 16
(1,647 Views)
thank you very much Smiley Happy
Now I will try to modify this program to extinguish a LED when the second is lit.
Thanks !
Message 13 of 16
(1,637 Views)
Just eliminate the shift register and use a plain, non-indexing input tunnel for the 2D array. The rest can stay the same. Try it.
Message 14 of 16
(1,634 Views)
my problem is solved Smiley Happy
thank you very much !
Message 15 of 16
(1,622 Views)
This is just the first step, now you need to do at leaast two things: (1) completely understand the purpose of every single code element and (2) expand it for other light patterns as an exercise.
Message 16 of 16
(1,613 Views)
