LAbview 8.5 Chart
Hello
I have a chart in a vi, configured as a sweep chart.
It is like every time it comes to the end, and will do auto scale labview
and everything dies with error codes..
Any one have a suggestion ?
Kasper
(3,024 Views)
Yes, be more specific and possibly attach a simplified VI that shows the problem.
  • What is "it"?
  • What is your OS?
  • What is "everything"? (program crash, LabVIEW crash, OS crash, end of the world, ...)?
  • What are the error codes?
(3,015 Views)
It would really help if you provided the actual error codes. Don't make someone try to guess. Attaching at least an image of your block diagram would also help. Attching the actual VI would be even better.
(3,012 Views)
"altenbach" <x@no.email> wrote in message
news:1192650009085-597237@exchange.ni.com...
> Kasper wrote:Any one have a suggestion ?
> problem.
> Kasper wrote:It is like every time it comes to the end, and will do auto
> scale labviewand everything dies with error codes..
> - What is "it"?
I have located it to be in the char when running in sweep char mode, the 2
other modes does not do it, even i a simle while loop with 10ms delay, and a
random generator connected to a chart in sweep mode, it crashes.
> - What is your OS?
XP
> - What is "everything"? (program crash, LabVIEW crash, OS crash, end of
> the world, ...)?
Program + labview crash
> - What are the error codes?
Differen, and comes fra win32 kernel
Kasper
(2,998 Views)
This works just fine here. I cannot reporduce this problem.
Such a VI works just fine in sweep mode (tried both the modern and the classic chart). Is there anything that prevents you from attaching the simple demo program you described? Maybe something is corrupt.
Since you apparently have other problems, make sure there is nothing wrong with your computer. Maybe check the disk for errors.
(2,993 Views)
