LAbVIEW, Linux and Application Builder
I'm using Labview under Linux.
I have written an apllication, the problem is that, when I try to build it, only "Source Distribution"  folder is created,  so you can see the VI code.
I would like to avoid this and only allow its execution.How can I do this?
I tried to change the file permission, but with  "chmod 111" permissions, the files are not even open.
Salvo
(2,896 Views)
Hi nept,
does your LabVIEW license allow you to build applications?
Did you activate the AppBuilder?
(The option "Create Source Distribution" is part of the "base" LabVIEW version - other options appear with an activated AppBuilder license.)
(2,894 Views)
Thanks for your reply.
I have "full edition".
I thought it was included.
Salvo
(2,865 Views)
Accepted by topic author nept
Hi Salvo,
@nept wrote:
I have "full edition". I thought it was included.
It seems you didn't select your edition carefully enough: NI shows that list to compare the editions! (Check the last part of the table…)
(2,861 Views)
thanks, I saw the table. It was bought by my institution.
(2,856 Views)
