LABview 8.5 MAthscripts problem
Hello
I have LABVIEW 8.5 that we bought 2007. My privious code included mathscripts program inside the LAb view code. Recently I did reinstall LABVIEW 8.5 on windows XP SP 2. I did install from the DVD profession development system. DVD number 501400H-1.
I have these  CDS
1. Full developement system
2. professional sytems
3. Measuremets studio enterprize s
4. toolkits
5. signal express
6. device drivers 1 2 3
7. NI LABview windows/CVI  full development system
I did install those  CDS too,
Problem:
I can not do anything on MATscript portion. I did run my old programs. then run, give me the results but I can not write any new prorams or edit old code. they locked. Cannot write/edit on MAThscripts. I have so many programs those are included MATScipts. Now I am stuck.
Should I install from CDs first or DVD is enough. is it .net problem, is it windows XP SP 2 problem?
. Please give me idea how can I get rid of this problem, how can I install properly. Which CDs contain the Mathscipts editor/ programs
Moin
Moin
Message 1 of 11
(5,325 Views)
You need to make sure you have LabVIEW 8.5 with MathScript installed and activated in NI License Manager (All Programs>>National Instruments folder).
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 2 of 11
(5,293 Views)
Whic CD cinatin the Mathscript module?
Didnt fint in NI folder.
Moin
Moin
Message 3 of 11
(5,281 Views)
Before LabVIEW 2009, MathScript was included with LabVIEW (e.g. LabVIEW 8.5 Full Development System with MathScript). It should be a separate LabVIEw installation. After LabVIEW 2009, MathScript became a separate module: MathScriptRT. Do you just have disks for LabVIEW 8.5 or LabVIEW 8.5 with MathScript?
Mikhail
RF Toolkits, Product Support Engineer
Message 4 of 11
(5,262 Views)
Mikhail,
I am having a similar problem.  I am running Diadem 11.0 and LabView 8.5 Professional and trying to use mathscript for an analysis. I get a data transfer error when I run the script.  I think Diadem is trying to run LabView but something is going wrong.  I do see mathscript files in the National Instruments/LabView 8.5/resource folder (mathscript.rsc, MathScriptExtCode.dll, MathScriptParser.dll).
Chuck
Message 5 of 11
(5,217 Views)
Does the MathScript code work if run from the LabVIEW Development enviornment? Or does this only have problems when using DIAdem?
Zach P.
Message 6 of 11
(5,203 Views)
Zach,
I am only creating the script in Diadem.  Attached is a screen shot of the script.  I am trying to do a calculation with multiple waveforms for input and a single waveform for the output.  If I could do Absolute values in the basic math funcitons then I could get what I want but it seems to me that using a Mathscript is the only way to do this.
Chuck
Message 7 of 11
(5,197 Views)
Spoiler
Zach,
Just to clarify, all of the inputs are data channels not waveform channels.
Chuck
Message 8 of 11
(5,183 Views)
Just tried the new equation but I get the same "Cannot transfer result data" error.
Message 9 of 11
(5,162 Views)
Hello Chuck,
      Break the equation into smaller pieces please and let me know which part of the equation is failing.   Just save the results into temporary place holder variables and we should be able to find the solution.
      Also,   Can you verify that the Arrays are the same size?   Double check any capitalization errors?
Daniel de Gaston
Applications Engineering
Message 10 of 11
(5,156 Views)
