LABVIEW and CVI
Is there some sort of tool able to translate directly from LabWindows CVI
to LabView and vice versa?
Thanks.
AR
(2,850 Views)
> Thanks.
> AR
You can go from CVI to LabVIEW using the "Convert CVI FP"
under the File menu of LabVIEW. You will need the *.fp and *.dll
You can not go the other direction though (ie LabVIEW to CVI)
at least not that I have seen.
Kevin Kent
(2,850 Views)
