LABVIEW S/N activation
   I had my labview 2014 activated in my old laptop and It worked fine. I now have a new laptop and I installed LabVIEW 2014 on it using the same DVDs. When I try to activate it with the same S/N number as the one in the old laptop, it says that the S/N is invalid. Why is that?
(2,618 Views)
Call NI.
Benoit
(2,573 Views)
To expand on what bseguin said, some licenses can only be used a set number of times, and it is possible that this serial has been used too much.  Contacting NI about this can clear up why it isn't working.  I wouldn't be surprised if NI lets you use it again by explaining a computer that once activated it has had LabVIEW uninstalled since then, or has be recycled.
(2,554 Views)
