LAB View
Hello
I,ve got an NI cDAQ 9185 with NI 9219 and 9112 inside.
Is it possible to get data without labview ? Nodered for exemple ?
Best regards
(1,406 Views)
Yes, you can use C#/.NET or Python or use the C DLL in the programming language of your choice.
If your question is "without any programming", please look at DAQ Express and Flexlogger. If you just want to test the channels, you can use the soft test panel that come with the driver from NI MAX.
Santhosh
Soliton Technologies
(1,385 Views)
