06-05-2020 04:21 AM
Hello semuanya
Saya ingin membuat program labview yang sinyal yang sudah saya dapatkan. Sinyal tersebut merupakan sinyal arah pergerakan bola mata. Saya ingin membuat program dengan algoritma sebagai berikut.
Saya telah membuat program seperti yang telah saya lampirkan di bawah. Akan tetapi, program tersebut tidak berjalan dengan baik. Karena ketika di beri sinyal dengan polaritas (+)(+) lampu yang hidup ada dua. Dan ketika diberi sinyal ke bawah tidak ada indicator yang hidup.
Bagaimana cara saya bisa mengklasifikasikan sinyal tersebut. Dan saya ingin membuat indicator berubah sesuai dengan sinyal yang diberikan, apabila diberikan sinyal Panjang seperti berikut, dimana ada sinyal kanan dan kiri.
Mohon Bantuannya
Terima Kasih
Solved! Go to Solution.
06-05-2020 08:58 AM
From Google translate :
I want to create a labview program which is the signal that I have gotten. The signal is a signal the direction of movement of the eyeball. I want to make a program with the following algorithm.
I have made the program as I have attached it below. However, the program did not work well. Because when given a signal with polarity (+) (+) lights that live there are two. And when given a signal down there are no indicators that are alive.
How can I classify these signals. And I want to make the indicator change according to the signal given, if given a Long signal like the following, where there are right and left signals.
What I understand :
| CH1>0 | CH2>0 | |
| Up | FALSE | FALSE |
| Right | FALSE | TRUE |
| Left | TRUE | FALSE |
| Down | TRUE | TRUE |
But Top and Left had the same condition.
I attach the new program. Does it do what you want ?
Yddet
06-06-2020 01:19 AM
Thank you for your response,
Yes, I want to classify signals based on the polarity. But I'm sorry, I can't open your vi because I use Labview 2012. Can I ask for the snippet or just the Screenshoot, so I can copy it to my program?
Jenni
06-06-2020 02:34 AM - edited 06-06-2020 02:42 AM
Halo semuanya
Salam kenal, saya Novi. Saya ingin membuat program labview untuk mendeteksi kedipan mata. Kedipan mata ini terdiri dari kedipan mata sadar, tidak sadar, kedipan mata kiri dan kedipan mata kanan.
Saya ingin membuat program dengan algoritma sebagai berikut :
Sinyal untuk kedip mata kanan, amplitudo ch1-nya lebih besar. Sedangkan untuk kedip mata kiri, amplitudo ch2-nya lebih besar. Dan untuk kedip sadar, amplitudo ch1 maupun ch2-nya akan lebih besar dibandingkan kedip tidak sadar.
Saya telah membuat program seperti yang telah saya lampirkan di bawah. Namun, program tersebut tidak berjalan dengan baik. Karena tidak bisa mendeteksi sinyal berdasarkan amplitudonya. Saya juga ingin membuat indicator berubah sesuai dengan sinyal yang diberikan, jika diberikan data sinyal yg banyak sebagai berikut.
Mohon bantuannya,
Terima kasih
06-08-2020 03:56 AM - edited 06-08-2020 04:02 AM
Jenni,
Please find attached the program in LabVIEW 2012
Novi,
From google translate:
Hello everyone, Greetings, I'm Novi. I want to create a labview program to detect eye blinks. This blink consists of blinking conscious, unconscious, blinking left eye and blinking right eye.
I want to program the algorithm as follows: Signal for right eye blink, amplitude ch1 is greater. As for the left eye blink, the amplitude of ch2 is greater. And for the conscious blink, the amplitude of ch1 and ch2 will be greater than the unconscious blink.
I have made the program as I have attached it below. However, the program did not work well. Because it cannot detect the signal based on its amplitude. I also want to make the indicator change according to the signal given, if given a lot of signal data as follows.
Although your problem is very similar, please post your own topic. It will be very messy if we start to solve two programs at the same place.
EDIT: I see you had your own topic but it was merged. I will have a look at your program later
Yddet
06-08-2020 04:46 AM
06-08-2020 08:55 AM
Thank you for your response Mr.Yddet, and thank you for attached the vi.
No, what I need actually is to classified the signals using the polarity, I want, when the polarity of the signals are (+)(+), it will be classified as Up signal, same goes with the left signals, when it becomes (-)(+), it will be classified as Left signal.
I have looked at the program which you attached, but why did the indicator always go to the Up indicator when the signals of each Channel are Zero Zero?
I have changed the threshold value, so the noise won't disturb.
Sorry for my error grammar, hope you understand it
Jenni
06-08-2020 09:44 AM
Jenni,
You have the truth table to decide when to turn the LEDs ON but you didn't gave it.
You have a beginning of program doing half the job, continue ! It's not optimised but will work if you continue modifying it. The code tests if the signal is positive, you need to add tests for when its negative.
I share a different way to achieve your goals in the attached program. You don't have to choose this solution if you are not confortable with it.
Yddet
06-12-2020 02:22 AM
Thank You for your response.
Actually the program which you attached helps me so much
Thank You for your help
Regards
Jenni
