Kintex xilinx coregen
Hi all,
I would create a cpu on my PXIe-7821R. When I run the xilinx coregen, the kintex does not appear in the list of supported fpga family.
Someone know how to do to get the kintex available for xilinx coregen ?
Thanks and best regards,
Benoit Chantepie
(3,630 Views)
Hello Benc,
Information concerning tools to use based on the device you have:
Xilinx Compilation Tools for Vivado 2013.4
Use the Xilinx compilation tools for Vivado 2013.4 to compile FPGA VIs for the following NI-RIO devices:
  • NI USB-785xR
  • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-797xR
  • NI cRIO-9068, NI cRIO-903x
  • NI USRP-RIO 294x, NI USRP-RIO 295x
Xilinx Compilation Tools for ISE 14.7
Use the Xilinx compilation tools for ISE 14.7 to compile FPGA VIs for the following NI-RIO devices:
  • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
  • NI PCIe-784xR, NI PCIe-785xR
  • NI PXIe-796xR, NI PXIe-564xR
  • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
  • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
  • NI 9144, NI 9146, NI 9148, NI 915x
You have to use Xininx Compilation tools for Vivado in you case.
Jovan N. - Application Engineering
(3,550 Views)
Hi ,
i have the samed probléme but with PXI7841R.
i installed FPGA module2014.
Real Time 2014.
i have 61499 error code at compilation.
  but when i want to download  Xilinx Compilation Tools for ISE 14.7 i found 4Go link but i obtain format.iso and not executable forme .exe
 thanks to propose my .exe to download if its  enough driver soft its my problem .thanks to join me  link to download correct ""Xilinx Compilation Tools for ISE 14.7"" with format .exe and not .iso wich not executable.
but if its not the probléme and i d'indt install Xilinx what can i do.
Thanks for all future advices
(3,444 Views)
Here is a link that explain how to mount an ISO file.
http://wincdemu.sysprogs.org/tutorials/mount/
(3,420 Views)
