Kinect with labview
I want to use Kinect with labview. My computer (window 7/32 bits) have Labview 2013 and .net framework 4.5.1. I look at the example" Using the Kinect with LabVIEW and the Upgraded Microsoft .NET API", download and installed NI VISION acqusition software 2013, Microsoft Kinect SDK 1.5, config file and Kinect SDK v1.0.zip. When i open the' Kinect Example.vi', it showed:" SubVI 'Kinect Library, Lvlib:Get Color Frame.vi': SubVI is not executable." Open the other VI, they also showed :"SubVI 'IMAQ ColorValue ToInteger': SubVI is missing, or SubVI 'IMAQ Copy': SubVI is missing". It seems there are a lot of SubVI were missing. Can you help. Thanks
Message 1 of 14
(7,359 Views)
maybe your SubVI 'Kinect Library, is older version than the LabVIEw you are running with. so you get the error Sub VI is not Executable. it happened to me in NI USB, when i upgrade my labview from 2009 to 2012, so i installed NI8451 for Labview 2012.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 2 of 14
(7,340 Views)
Thanks. I checked the Kinect Library was modefied in 2012. Do you think the config file ( runtime version= "4.0.0xxx") is OK for .net framewor 4.5.1. Do you know where to download example for kinect using Labview?
Message 3 of 14
(7,310 Views)
hi Joan331,
I would suggest this Toolkit from the University of Leeds:
https://www.ni.com/en/support/downloads/tools-network/download.kinesthesia-toolkit-for-microsoft-kin...
besides LabView you will have to install:
- Microsoft .NET 4.0 Framework or higher
- Microsoft Kinect SDK 1.0 or higher
Alex
Message 4 of 14
(7,290 Views)
Thanks. Do you think Microsoft Kinect SDK software need to work with microsoft visual studio?
Message 5 of 14
(7,270 Views)
The Microsoft Kinect SDK streamlines the connection between the Kinect and a windows  machine.
What does "work" mean in this context?
Message 6 of 14
(7,232 Views)
Do I need the 'NI Vision acquisition software' to add Kinesthesia Toolkit for Microsoft Kinect? I download the 'NI vision acquisition software 2013', but it only for evaluation only. Is possible to get free NI Vision acquisition software? Thanks.
Message 7 of 14
(7,194 Views)
The Kinesthesia Toolkit contains some Vision Acquisition VIs  inside, but you don't need those for recording (e.g.  RGB image, height image or sound) or to control the kinect's motors.
Those VA VIs are rather used to display the recorded data.
But I think it will be much easier to use Kinesthesia with VA installed, especially if you have little experience in image processing:
Message 8 of 14
(7,187 Views)
Thanks a lot. I try the kinect_ example. It seems working. But i have question, the video was kept jumping and the 3D Skeleton only show a point. How to improve it. Also how to save video into file. Please help. Thanks.
Message 9 of 14
(7,149 Views)
your description is very vague, so I can only make some guesses:
maybe you should decrease the kinects framerate (fps) to merge with your output device.
 I never used the 3d Skelton image.
Maybe some configuration issue?
I can't help you with this topic - it should be easily feasible with Vision IMAQ:
http://forums.ni.com/t5/LabVIEW/webcam-continuous-capture-and-save-to-avi-later/m-p/1630554/highligh...
Alex
Message 10 of 14
(7,138 Views)
