Key Navigation
Hi
I have a Key Navigation problem. I can only use keyboard and cannot use mouse or touch screen in my application. I am using LabVIEW 2015 Service Pack 1, Version 15.0.1f10 (32-bit).
When my program is running, if I press "Esc" and then press "Enter", the "Enter" key acts as "Esc". i.e. I press "Enter", It toggles the "Esc". The same thing happens with the other two keys, "Home" and "Del". I did not sign the "Enter" in the Key Navigation, but why when the program is running, after I press any of the three keys, "Esc", "Home" or "Del", and then press "Enter", the program responses?
I have attached my simplified program. Any help will be appreciated.
Steve
(2,728 Views)
Accepted by topic author Shijie
Your code works as expected (for the configured options). The program responds only after the 10s loop.
You would need to disable focus for all buttons so that the "Enter" key is not toggling the focussed button
Santhosh
Soliton Technologies
(2,721 Views)
Thank you very much.
(2,713 Views)
