Key Navigation when window doesn't have focus
Using key navigation I want to allow the user to instigate a program function by with a key sequence like Ctrl-F1. This works fine as long as the window has focus but does not work if another window is active. Is there any way to get my vi to respond to the key sequence when that vi does not have the focus?
(3,032 Views)
I believe the answer is NO, you can't get around this.  This is an OS issue of directing the key press to the application that has focus.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,025 Views)
You can use the keyboard input VIs to continuously poll for that key combination. Not as good as an event, but will work without focus. The VIs can be found in the Advanced palette before 8.0 and in the Connectivity palette (I think) later.
___________________
Try to take over the world!
(3,021 Views)
Yup!  Tested it myself and it will work.  Good save fro my flawed answer.  It will not work they way initially specified but should work by using the keyboard VIs.
Thanks!
Matthew Fitzsimons
(3,015 Views)
