Keithley 6517B Saving data to text file
I'm using a program on LabVIEW that works for the KE 6517B attached (2015), however I want to save my data to a text file without overriding previous data.
I need a way to either prompt a new text document every time or simply add on to a previously used text file.
Thank You.
(3,036 Views)
Accepted by topic author theInfiniteOne
I can't open your VI since I only have LabVIEW 2017 installed.  But its easy enough to implement what you want..
(3,012 Views)
Sorry I thought I saved it to 2015. I'll try again
(3,007 Views)
Hi mate, In your code, I changed the "Selection Mode" of Path icon in front panel into "new or existing" and I modified block diagram as the attached pic shown, it can save data now! Thank you very much. best regards, Cheng block diagram 1.jpg
(2,479 Views)
