Keithley 6517 real time measurement and sampling frequency
I am using keithley's 6517 Electrometer. I have connected this instrument to my PC via GPIB.I am doing dynamic pressure measurement and I need to sense how charge or voltage changes with respect to time during dynamic pressure applied via piston to a liquid.
I have two queries
a) I want to know the sampling frequency or time interval of measurement of this instruement as dynamic pressure pulse lifetime in my application is only 3ms. I want to read changes in charge or voltage in micro second time interval. Is it possible with this 6517 instrument?
b) In addition, I am using labVIEW 2012 and using "keithely 6517 example.vi" program that comes with driver as an example.Is it possible to create a graph which shows real time changes of charge with respect to time?
PS: I have attached labview file which I am using now
Any kind of help or suggestion would be appreciated.
Thank you
Message 1 of 12
(6,897 Views)
Have you read the manual or looked at Keithley's web site - http://www.keithley.com/products/dcac/voltagesource/application/?mn=6517B? It clearly states the sample rate.
Message 2 of 12
(6,882 Views)
thanks
Yes I saw it..it can read 425 reading per second..means sampling rate is around 2.4 ms
Message 3 of 12
(6,867 Views)
So Its impossible to get micro second sampling rate
Message 4 of 12
(6,865 Views)
Unless you're wanting to sample every 2400us, then yes it's impossible to get a sample in microseconds.  The device tells you that from the start.
Message 5 of 12
(6,858 Views)
And how to get real time graph of a charge or voltage in labview
Message 6 of 12
(6,837 Views)
You pass an array of values to a graph. If you acquire a single point at a time, you pass the scalar to a chartinstead. Show where you are stuck.
Message 7 of 12
(6,832 Views)
finally I did it. I made it very complicated
Message 8 of 12
(6,818 Views)
Hii pateIMIKES,
I am trying use your Labview program attached (6517.vi) in previous message but SUB-VIs of following were missing while running this program,
1. Keithey 6517 coulombs config.vi
2. Keithley 6517 Single read.vi
Can you send the Sub-VI files or Driver files you used for this program. Looking forward your reply.
Thanks in advance.
Warm Regards,
Jagadeesh G
Email: jagdeesh.g93@gmail.com
Message 9 of 12
(5,983 Views)
I am running into an issue with the code as some sub-VIs are missing can you send me these
(Keithey 6517 coulombs config.vi) & (Keithley 6517 Single read.v). I'd really appreciate it.
delacresse@gmail.com
Message 10 of 12
(5,520 Views)
