Keithley 2701 Scanner
This is my first experiment using Labview 8 and third party hardware (Keithley 2701 with a 7703 32-channel scanner card).
I'm hoping someone can help me with a small VI example or some advice.
I have all the updated drivers from Keithley, I'm trying to set up and scan 32 DC voltage channels. No matter which drivers/functions I choose from the pallette, I can't seem to scan more than one channel. If I pass a channel list, it gives me an error 221 (settings conflict).
I realize that this is not NI hardware, but Keithley doesn't seem helpful at all. And their documentation isn't the best.
If I could see either a simple example showing which functions need to be called and the parameters, it would be great.
I also have an Agilent 6050 load which has labview drivers. I have no problems with this hardware.
Any ideas before I contact Keithley again?
Jeff
(3,130 Views)
I used this instrument at my previous job with two of the plug-in modules. Using LabVIEW 6.1 at the time. Didn't have any trouble with it.
I'd suggest sending commands using MAX to make you understand how the instrument and commands work.
(3,118 Views)
Ok thanks I got it working.
It was just the order of operatoins. 🙂
Jeff
(3,113 Views)
