Keithley 26xx sweep mode from -V to +V and vice versa measurements
Hi.
I am using the Keithley 26XX drivers from Keithley's website to measure Current Vs. Voltage.
I am trying to use thier sweep example to measure from -V to +V and vice versa , and then show it on graph.
Any suggestions ? In thier sweep example I can only measure one direction and I dont have the ability to show it on graph with X axis (it only gathered Y values)
Thanks.
Sagi
(2,588 Views)
I have not been too impressed with Keithley's VIs, although these are somewhat better than the ones I have used for the 2400.
I suggest that you take their examples apart and use them as starting points for your own program. I would use a state machine architecture.  Have states for initialization, sweep, measure, reconfigure for reverse sweep, save to file, and so on.
Lynn
(2,583 Views)
