Keithley 2602B 'Error Cluster from Error Code' VI Missing
I have installed the Keithley 2600 Series Drivers in my instr.lib folder - I know this is working as the instrument functions are appearing in the instruments I/O box.
When I try to open an example VI from the Keithley 2600 driver folder, I am prompted to find the 'Error Cluster from Error Code.vi' file but from what I can see this does not exist. This stops me from doing anything with the Keithley unit as it breaks most SubVIs and I get an error code.
Has anyone encountered this issue before and if so how do I go about fixing this issue?
Thank you for the help!
(850 Views)
Very strange, this is standard LabVIEW's VI, usually located in vi.lib\Utility\error.llb\Error Cluster From Error Code.vi
try to relink manually if LabVIEW unable to locate it automatically on open
(819 Views)
