Keeping automation refs open
I have been trying to store some automation refs in LV6.1 globals, but when the VI is stopped then re-run the reference is no longer valid. It seems LabVIEW is destroying the objects between runs.
My VIs are going to be run in TestStand 2.1 and I plan to configure the instruments in one sequence then use them in another. I hope to keep various sub-refs (measurement objects etc) open between sequences, how can this be achieved? I tried adding more automation opens and setting the "open new instance" boolean input to FALSE on the consecutive automation opens, that does not work. I guess I could try holding the refs in TestStand, but to save time and head ache, has anyone worked around this before?
Any help much appreciated.
LV6.1, TS
2.1, NT4 - controlling Agilent PNA E8358A using 835x.tlb
Certified LabVIEW Architect
(2,779 Views)
Are you trying to keep open an automation ref to a VI or an instrument handle? Instrument handles need to be kept open by TestStand and there's an example - \Examples\SessionMgr\LV\LVDmm.seq that demonstrates this with an IVI instrument. Also, with the more recent versions of VISA, you don't need a VISA Open to create a reference. VISA Write and Read accept resource names (i.e. "GPIB::2" or an alias) and automatically create a reference if one doesn't exist. There's probably some time penalty but but it makes the coding easy.
(2,777 Views)
Yes I'm trying to keep an automation ref to an instrument open. I'll keep it open in TestStand and not LabVIEW, thanks for the guidance.
(2,777 Views)
I'm running into the same problem, but I don't have the option of doing this through TestStand. I'm controlling a device in Labview 7.0 through a serial port using ActiveX automation and I want to keep the connection open while I open and close subvis. There is, indeed, a significant time penalty if I try it the way you suggest, and obviously there's a time penalty if I have to keep opening and closing the connection. Is there another way?
(2,777 Views)
